Radio Network with ProppFrexx
marinohb
Post by marinohb »
It's possible to rebroadcast a station with different commercial ads on both stations? For example, I have a main studio A but a station in another city, but I want to play different ads on each.
Let me know if there's a command or something for that.
meisterpropper
Re: Radio Network with ProppFrexx
Post by meisterpropper »
I think you can try multi-region support, but I don´t know, if you can switch between different region streams, whenever you play out an commercial container.
Yes. This feature is called "Multi-Region Advert/News support".
However, this is not as simple as a just using a simple command or setting.
The work to be done to set this up is roughly explained here:
http://www.proppfrexx.radio42.com/forum ... f=4&t=1744
