WaveShell-VST 64 bit not accepted
moerbie
Post by moerbie »
Hi everyone,
The waves vst 64 (WaveShell-VST 9.91_x64.dll) works with every other daw but is not accepted by proppfrexx v4.0.3.85 64-bit
Some help please
Thanks
Re: WaveShell-VST 64 bit not accepted
When you google for WaveShell issues you find tones of problems for almost all DAWs ;-)
Waves plugins can only run in applications that support VST Shell Plugins - ProppFrexx doesn't support this format, as it is not really a standard VST format and only Waves seems to use it.
You might try Shell2VST, but I am not sure, if a 64-bit verion exists.
Else WaveShell VSTs are not supported by ProppFrexx.
moerbie
Post by moerbie »
Ok, thx for your quick reply! Happy newyear!
