Hook
djbony
Hook
Post by djbony »
If I put 2 same song to the playlist and I set HOOK option on one of them, why they both change? Bug (PHOA 4.0.4.14 today update)? Thanx, Petr.
Re: Hook
Can you explain where and how you change the Hook option?
If I try it here and select just one of the two tracks and then press ALT+H (same as a right-click -> Track-Settings -> Toggle Hook Option) only that selected track is changed.
Same, if I load both tracks to DJ Players A and B and toggle the Hook from the DJ Players HOOK button - only the single one gets changed.
So it seems, that I cannot reproduce your issue.
djbony
Re: Hook
Post by djbony »
djbony
Re: Hook
Post by djbony »
Here is an even better example:
https://photos.app.goo.gl/aqzoejV2T08SJyH42
Re: Hook
Ah, now I see the issue, it only affects tracks also loaded to a DJ Player!
It will be fixed in the next version.
djbony
Re: Hook
Post by djbony »
Thank you very much. Good night.
djbony
Re: Hook
Post by djbony »
Hi Bernd, all works after last update... But... If Dj player is loaded and I use Alt+H in playlist on loaded track, DJ Player doesn't update to HOOK...
Re: Hook
Yes, this is by design. Alt+H changes the option of the track in the playlist.
Use the HOOK button in the DJ Player, if already loaded.
djbony
Re: Hook
Post by djbony »
I know, but if I prepare song examples for next times, I am working in playlist and copy existing songs in playlist for the quit. Then I change it to the hook - still in playlist with keyboard. Some are uploaded to DJ player, others are waiting. Your design impractical in this case :)
Re: Hook
I am not sure, why my design is impractical. There is a difference when a track is loaded to a DJ Player or not.
I even do not understand, why certain tracks are already loaded to a DJ Player when you just prepare the list.
Maybe you have set the 'AutoLoad' option in the general Playlist Settings (you might try to disable this option)?
