unix-timestamp format
erdmaennchen72
Post by erdmaennchen72 »
hello @ all / hello bernd,
Thanks Bernd for the short help via email,
with the suggested solution $ {yyyy} $ {MM} $ {dd} $ {HH} $ {mm} $ {ss} I did not get any further, I would need the command that gives me the unix-timestamp,
13.01.2018 23:39:04 --> 1515883144
Danke Bernd für die kurze Hilfe per Email,
mit dem lösungsvorschlag ${yyyy}${MM}${dd}${HH}${mm}${ss} kam ich nicht weiter, bräuchte den befehl das mir den unix-timestamp ausgibt,
Re: unix-timestamp format
ProppFrexx is a Windows based application.
There is no macro which delivers a Unix timestamp, which is the number of seconds sind 1970. guess you need to ask your target application to convert it.
