Problem With remote voicetrack
mdegroot
Post by mdegroot »
Since yesterday i can’t connect to remote voicetracking anymore. I always get the error : connection error. Unable to Find assembly zyan.communication ....
I Use it daily and until yesterday iT worked fine.
Pc has Windows 7 and is only running proppfrexx and the airlite driver. Updates are disabled, no firewall, latest proppfrexx version.
I tried with a backup restore but still not working.
I tested it on a second Windows 7 computer in the vt studio and same error. When i do the same test with a Windows 10 laptop, Connected to the same lan switch in the studio it does work. So its not a network problem or a problem at server side.
I don’t know what’s going wrong here.
I hope you can help.
Grts,
Benny
mdegroot
Re: Problem With remote voicetrack
Post by mdegroot »
Update to 4.0.4.23 solved the issue. Thx
Please make sure to use the same version on both the client and the server.
But, please just also (re)try the v4.0.4.23-update again, as I just fixed a version numbering issue – which might have caused this as well.
