Overlay problem
Soulmaster
Overlay problem
Post by Soulmaster »
I got a very strange problem with my overlays. Every hour proppfrexx has to start the Top Of The Hour, and it does. But after a 20 seconds the overlay screen is gone and the playlist is starting again so you hear the TOTH and the playlist..
In the overlay script i got both SuppresHistoryCheck and SuppressAdHistory on but still the TOTH is playing and the playlist..
Re: Overlay problem
If I understand you correctly you say both play in parallel together.
What exact version of ProppFrexx are you using.
And what StartType is your program as well as your Overlay? Please provide screenshots of both entries.
Also describe, what you are doing in your Overlay script. Are you maybe downloading some external file right at the time when the overlay is scheduled, so that the length is not known at that time?
Please activate the Debug Logging in the general settings, section More Stuff. Then reproduce the problem and send me your Debug_ .lig file which is contained in your global log file path.
Re: Overlay problem
Any news?
Re: Overlay problem
Assuming it solved now...
