Vertical & Horizontal Songs Rotation
Ahmed Saied
Hi Admin ,
I have an issue that related to the repetition of songs specially at A,B,C Playlists ... its the new songs playlists according to radio programing principles , so can you help me to avoid the vertical repetition at the same day , and horizontal repetition at the different day ,but at the same time .
Can you give me references or options to face this problem .
Thank you for caring
Re: Vertical & Horizontal Songs Rotation
Vertical: Take a look to the Global Restriction "Do not play a track again in the same hour plus/minus:" X hours.
Horizontal: Take a look to the "Global Song History".
Both can be found in the general settings, section 'Logging/History.
And are explained in this tutorial video: https://youtu.be/fJknoxnXOAQ
Ahmed Saied
Thanks a lot its good options really
I have 1 question also , in my Global Log cat .
the log file entries is : ${now}, "${artist}", "${title}", "${genre}"$,${directoryname}${CRLF}
I want to add the name of each playlist that songs was taken from it .
Have you an option to satisfy this ?
You can use any global macro in the global log file, e.g. ${progcurrentname} or ${cplname}
Take a look to the User Manual Appendix, there you'll find all available macros listed.
