ASYNC trouble
moogwill
ASYNC trouble
Post by moogwill »
Hi bernd,
It seems an old issue is back,
here's the commands used on the event streaming/on songtitle changed
EXEC_WRITE_FILE d:\baseplayloud\nowplaying\nowonair.txt|nd|${artist} - ${title}
EXEC_WRITE_JPEG_FILE d:\baseplayloud\nowplaying\now.jpg|0|300
ASYNC
EXEC_SEND_MIDI_SYSEXMSG 0x90 0x46 0x64
SLEEP 10000
as we did change this using async in the past, everything went fine for a long time but now, all command buttons from airence mixdesk are useless until sleep time is over (that was the original issue) is this comes from the last update?
moogwill
Re: ASYNC trouble
Post by moogwill »
it seems I maybe found a working solution by myself using this, correct me if I'm wrong
EXEC_ASYNC EXEC_SEND_MIDI_SYSEXMSG 0x90 0x46 0x64${CRLF}SLEEP 10000${CRLF}EXEC_SEND_MIDI_SYSEXMSG 0x90 0x46 0x64
Re: ASYNC trouble
This is not back, you just used it 'incorrectly' ;-)
Your 2nd post is correct, as the ASYNC keyword stand-alone is ONLY recognized when given at the very beginning and would then apply to all commands.
moogwill
Re: ASYNC trouble
Post by moogwill »
thanks...
is there any trouble using this alternative above??
Re: ASYNC trouble
No, that is perfectly good!
