Propp stops playing when diconnecting from rdp
Erris
Post by Erris »
I'm using propp on a remote pc for 24 streaming and playing, but when i login via rdp an i use disconnect, the whole player stops.
Erris
Re: Propp stops playing when diconnecting from rdp
Post by Erris »
Thank for the explenation i'm gonne try it :)
You probably have used the default configuration of Remote Desktop. This means the soundcard settings will be stolen on the remote PC to also transmit the sound to the client.
When disconnecting those virtual devices will be destroyed. This might lead to devices being unavailable when disconnecting.
For real-time audio applications you therefore should disable the sound options in your Remote Desktop settings!
Laurens
Post by Laurens »
The other issue could be that the Remote Desktop Connection locks the computer after disconnecting.
I don't know what Proppfrexx would do when you lock the computer when it is playing?
Locking wouldn’t stop the audio normally.
Disabling the computer sound with the Remote Desktop should do the trick.
