Directory Explorer Column Layout
TDDxD
Post by TDDxD »
Hello!
How do I save the Directory Explorer layout?
There doesn't seem to be a way to save the layout and I have to manually configure it every time after adding new music to the media library.
Thank you!
TDDxD
Re: Directory Explorer Column Layout
Post by TDDxD »
Thank you! Turns out I just had to close and re-open PFOA. :D
The layout of the Explorer within ProppFrexx ONAIR is saved when you close ProppFrexx and restored when you start it again.
The layout is also only saved resp. restored in case you have not disabled the following options in your general settings, section 'Look and Feel':
- Load Layout on Startup
- Save Layout on Exit
