Repeated unhanded Exception clicking to add programme slot in schedule
phonic
Post by phonic »
Repeated unhanded Exception clicking to add programme slot in programme scheduler. It will display the popup window, if you close the error box and try again 2 or 3 times.
25-May-19 4:49:03 PM [v4.0.5.35]:********** Error/Exception Information **********
Error Source: ProppFrexx ONAIR.Void SQRu(System.Object, DevExpress.XtraScheduler.PopupMenuShowingEventArgs)
at ProppFrexx.OnAirScheduler.SQRu(Object , PopupMenuShowingEventArgs )
at DevExpress.XtraScheduler.SchedulerControl.RaisePopupMenuShowing(PopupMenuShowingEventArgs args)
at DevExpress.XtraScheduler.SchedulerControl.CreatePopupMenu(Point point)
at DevExpress.XtraScheduler.SchedulerControl.OnPopupMenu(Point point)
at DevExpress.XtraScheduler.SchedulerControl.OnWmContextMenu(Int32 lParam)
at DevExpress.XtraScheduler.SchedulerControl.WndProc(Message& m)
********** End **********
Re: Repeated unhanded Exception clicking to add programme slot in schedule
Unfortunately I can not reproduce this issue here on my side.
Have you tried to reboot our machine? Is the issue/exception constantly coming up?
If yes, can you send me your "ProppFrexx ONAIR.calendar" file?
phonic
Post by phonic »
radio42 wrote: 25 May 2019 23:45 Unfortunately I can not reproduce this issue here on my side.
I've since restarted ProppFrexx, and seems to be happy at the moment.
It's not just the double left clicking, as even a right click was bringing up the same error box. But was intermittent, as 3 attempts of closing the error box would make it work again, but also same was true for the error box after 3 working attempts back came the same error, and had to keep clicking and closing the error box until it worked again.
The official v4.0.5.38 update fixes this issue!
