Just had this error while pressing to start a song
phonic
Post by phonic »
23/11/2019 10:39:51 [v4.1.4.4]:********** Error/Exception Information **********
Error Source: DevExpress.XtraEditors.v19.1.System.Drawing.Size CalcDescriptionSize(DevExpress.XtraEditors.TokenEditToken)
at DevExpress.XtraEditors.ViewInfo.TokenEditViewInfo.CalcDescriptionSize(TokenEditToken token)
at DevExpress.XtraEditors.ViewInfo.TokenEditViewInfo.CalcItemSizeCore(TokenEditToken token)
at DevExpress.XtraEditors.ViewInfo.TokenEditViewInfo.CalcItemSize(TokenEditToken token)
at DevExpress.XtraEditors.ViewInfo.TokenEditViewInfo.CalcRowCountCore(Int32 clientWidth)
at DevExpress.XtraEditors.ViewInfo.TokenEditViewInfo.CalcRowCount(Int32 clientWidth)
at DevExpress.XtraEditors.ViewInfo.TokenEditViewInfo.CalcConstants()
at DevExpress.XtraEditors.ViewInfo.TokenEditViewInfo.DoUpdateSelectedItems()
at DevExpress.XtraTreeList.Painter.TreeListPaintHelper.DrawNodeCell(CustomDrawNodeCellEventArgs e)
at DevExpress.XtraTreeList.Painter.TreeListPainter.<>c__DisplayClass85_0.<DrawCellCore>b__0(GraphicsCache cache, AppearanceObject appearance)
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawCellCore(CellInfo cell, CustomDrawNodeCellEventArgs e)
at DevExpress.XtraTreeList.CustomDrawEventArgs.DefaultDraw()
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawCell(CellInfo cell)
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawCells(RowInfo ri)
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawRowCore(RowInfo ri)
at ProppFrexx.Playlist.oQdM(Object , CustomDrawRowEventArgs )
at DevExpress.XtraTreeList.TreeList.RaiseCustomDrawRow(CustomDrawRowEventArgs e)
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawRow(TreeListDrawInfo e, RowInfo ri, Boolean isAutoFilterRow)
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawRows()
at DevExpress.XtraTreeList.Painter.TreeListPainter.DoDraw(TreeListViewInfo viewInfo, GraphicsCache cache)
at DevExpress.XtraTreeList.TreeList.OnPaintCore(GraphicsCache cache, PaintEventArgs e)
at DevExpress.XtraTreeList.TreeList.OnDirectXPaint(GraphicsCache cache, PaintEventArgs e)
at DevExpress.XtraTreeList.TreeList.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
at System.Windows.Forms.Control.WmPaint(Message& m)
at DevExpress.XtraEditors.Container.EditorContainer.WndProc(Message& m)
at DevExpress.XtraTreeList.TreeList.WndProc(Message& m)
********** End **********
Re: Just has this error while pressing to start a song
That looks very strange.
Can you reproduce this error, as I can’t.
Does it only happen with a particular track (if yes, please can you send that over to me).
phonic
Post by phonic »
It was not excepted, we are currently live and thankfully it did not close ProppFrexx.
One thing I noticed is that the playlist did not scroll, so had to open new playlist, and seems ok at the moment.
As said, please try to reproduce the error, if that happens only with a particular track within the playlist.
As I can absolutely not reproduce it here.
I have however opened a ticket with my UI vendor, as the error occurred inside their UI library - maybe they can spot anything.
phonic
Post by phonic »
radio42 wrote: 23 Nov 2019 12:39 As said, please try to reproduce the error, if that happens only with a particular track within the playlist.
Thanks for opening a ticket.
It was a big panic yesterday when the error appeared on screen in the middle of a live event on DAB around the country. First time in using ProppFrexx in a live show.
I could not check what track was causing the issue as we were live all day doing a road show. The only difference is at the time of the error, we were using the remote app I created to start the song by sending the commands via TCP.
I've checked the track, and works fine as usual. I will run more checks in the week to try and reproduce on the same computer with the app.
Thanks again for your prompt support.
