Moving news slot around via mouse produced this error
phonic
Post by phonic »
Using: 4.1.5.6 - Not had this before, but moving news slot around via mouse in the overlay scheduler produced this error:
Send via bug report.
at DevExpress.Utils.DXCollectionBase`1.ThrowIndexOutOfRangeException()
at DevExpress.Utils.DXCollectionBase`1.GetItem(Int32 index)
at DevExpress.XtraScheduler.Native.AppointmentChangeHelper.BeginInternalDragDrop(SchedulerDragData dragData, ISchedulerHitInfo aptHitInfo)
at DevExpress.XtraScheduler.Native.AppointmentInternalDragMouseHandlerStateBase.Start()
at DevExpress.XtraScheduler.Native.AppointmentMouseDownState.OnMouseMove(MouseEventArgs e)
at DevExpress.Utils.MouseHandler.HandleMouseMove(MouseEventArgs e)
at DevExpress.XtraScheduler.Native.SchedulerMouseHandler.OnMouseMove(MouseEventArgs e)
at DevExpress.XtraScheduler.Native.WinFormsSchedulerMouseHandler.<>c__DisplayClass42_0.<OnMouseMove>b__0()
at DevExpress.XtraScheduler.Native.SchedulerLocker.DoLockedActionIfNotLocked(Action action)
at DevExpress.XtraScheduler.SchedulerControl.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at DevExpress.XtraScheduler.SchedulerControl.WndProc(Message& m)
********** End **********
Re: Moving news slot around via mouse produced this error
This looks like a bug in the UI lib I am using. I’ll report this to the UI lib vendor and keep you informed.
Can you clearly reproduce this issue by dragging scheduler items around?
phonic
Post by phonic »
radio42 wrote: 11 Mar 2020 18:47 This looks like a bug in the UI lib I am using. I’ll report this to the UI lib vendor and keep you informed.
Thanks for your help!
phonic
Post by phonic »
radio42 wrote: 11 Mar 2020 23:07 Can you clearly reproduce this issue by dragging scheduler items around?
The overlay scheduler stoped responding after I closed the error box, so as a precaution I restarted ProppFrexx, it has not errored since.
I've tried moving items around for the passed 5 minutes, discarding changes and trying again, not seen any errors yet.
Did you had a chance to reproduce it - as I was not able to?!
So maybe a one time strange issue?
phonic
Post by phonic »
radio42 wrote: 28 Mar 2020 13:18 Did you had a chance to reproduce it - as I was not able to?!
I've not had the chance to do more focused tests with moving the overlay slots around, but in daily use since I restarted ProppFrexx the issues has not reappeared when I've opened or edited slots.
