Set Autoplay for a few elements only
meisterpropper
Post by meisterpropper »
is it easily possible to enable autoplay for a few elements in the playlist - it´s called "verketten" in some german radio broadcasting systems? For example you´ve got a few songs with sweeper etc, which should run at autoplay while the automation itselfs runs on manual mode.
Re: Set Autoplay for a few elements only
Yes, you can set on each of those tracks the track option called 'AutoPlayNext' (e.g. in the TAG Editor or in the playlist context menu under Tack Settings -> Options).
If set, the next track will be played, even if AutoPlay is OFF.
