Integrating with other sound softwares
GraceHuang
Post by GraceHuang »
Can proppfrexx onair integrate with g selector?
Re: Integrating with other sound softwares
Yes, ProppFrexx can integrate with a lot of external schedulers, e.g. Music1, PowerGold, MusicMaster any many more.
E.g. take a look here: https://www.proppfrexx.radio42.com/foru ... ?f=9&t=701
So far there is no direct integration with G Selector from RCS. But, if RCS can provide a similar log export file, like all the other external schedulers can do than this should be possible. E.g. via a fixed length or comma separated field list in a normal text file.
The only mandatory fields are basically a date/time field as well as a file reference to the audio file.
