Cardwall / D&R Airlite
Re: Cardwall / D&R Airlite
This forum is in English! I don't speak Dutch!
Please read this complete thread, as it might address the same issue (from reading your topic/subject): viewtopic.php?f=9&t=2237
See the post I shared above. This question was exactly answered there. In short: yes this works.
How? Read the thread
franksiegers
Not sure if this was exactly the same question. If I'm not mistaken, the thread explains how to get a blinking light on the airlite while playing a cart.
But the question that henkieturbo asks (and what I'm also interested in): Is there an event for when selecting (not playing) a cart.
For example: all "cart buttons" on the Airlite are green in my default config. It would be nice if I could select a cart entry with my mouse and the corresponding button on the Airlite would turn red. That way it's more easily to find and press that button to start the cart.
Thanks again,
Frank.
Thanks again,
Frank.
Oh sorry, I thought this is clear, as all cartwall events are located in the general settings, section Events/Commands and in the event tree, see the 'Cartwall' node. There you'll find an OnCartwall1/2Selected event - I assumed, that this is known resp. you could find it yourself!
Note, that this event is triggered for ALL carts whenever a selection of a cart in the cartwall is changed!
E.g. when you have 20 carts in your cartwall and change the selection, 20 events will be raised (for each cart individually).
You can use the macros ${cartid} and ${cartisselected} to determine its selection state (1=selected; 0=unselected).
Note, that you can select multiple carts!
Example for testing:
Probably you might use the following command to set the LED with the OnCartwall1Selected event:
SHOW_ALERT_WINDOW ${cartid}|${cartisselected}Code: Select all
EXEC_SEND_DRAIRENCE_SETLED *[TOINT:{${cartid}}:{vert}:{8}]|${cartisselected}Bernd - radio42
franksiegers
Thanks, it's (partically) working!
I have to be honest: These commands and parameters are kind of rocket science to me. Could you perhaps help with the following:
The Airlite has 2 vertical columns of control buttons. The buttons in the left column are numbered 1 through 8, right = 9 through 16.
My cartwall in PFOA also has two columns with 8 carts but the left column contains odd numbers and the right column contains even numbers. I would like the numbers to match the Airlite.
I get that I should use some math using 'TOINT' but cannot comprehend how to accomplish it. Another question is how to define the led color. Your example makes the button red. I tried to use green by adding '|2' after the parameters but that did not work.
Thanks for your patience and time!
Greets,
Frank
Greets,
Frank
I guess you can use the above example, can’t you?
So please explain exactly WHAT is not working - a statement like 'partially' is not enough!
When you use this command as shown above - what is the issue with it?
Maybe this post also helps:
https://www.proppfrexx.radio42.com/foru ... 537#p13350
EXEC_SEND_DRAIRENCE_SETLED *[TOINT:{${cartid}}:{vert}:{8}]|${cartisselected}https://www.proppfrexx.radio42.com/foru ... 537#p13350
franksiegers
I must be doing something wrong cause the numbering is off:
This is what happens when p1=8 or 16:
1 on PFOA = 1 on Airlite
2 on PFOA = 3 on Airlite
3 on PFOA = 5 on Airlite
4 on PFOA = 7 on Airlite
5 on PFOA = 9 on Airlite
6 on PFOA = 11 on Airlite
7 on PFOA = 13 on Airlite
8 on PFOA = 15 on Airlite
9 on PFOA = 2 on Airlite
10 on PFOA = 4 on Airlite
etcetera. I would like:
3 on PFOA = 2 on Airlite
2 on PFOA = 9 on Airlite
3 on PFOA = 10 on Airlite
What should p1 be?
The user manual at
http://www.proppfrexx.radio42.com/downl ... 20v4.0.pdf does not state 'vert' as a parameter of 'TOINT'.
What should p1 be?
The user manual at
franksiegers
Hi Henk,
This is what I tried:
https://imgur.com/a/YrYz843
But like I said: The wrong button on the Airlite lights up. Hopefully we can get that fixed.
Greets,
Frank
Greets,
Frank
The specific mapping you indicated in not what the ‚vert‘ function doing.
I’ll enhance the macro function with an additional mapping which also matches yours and post an update later today!
franksiegers
Can I find this update somewhere or did you not have to time to finish it yet?
Thanks,
Frank
Thanks,
Frank
