Generating playlists
This forum is unmoderated!
Radiofreak
Post by Radiofreak »
just a question out of curiosity. why is it not possible to generate playlists for several days or weeks so you know what's coming and you can voice track In advance.
Re: Generating playlists
This is possible - You can do this!
See the general settings - Folders/Libraries - and click on the Scheduler Automation... button. Here you'll find a group to Pre-Generate your Program/Playlist in advance. This is the automatic way to pre-grenerate playlists for your scheduled programs.
Alternatively you can do this also manually: Open the Program Scheduler, right-click on a specific program and then select 'Create Playlist Template...'.
In addition you can use the 'Playlist Template Wizard...' which you can find when clicking on the arrow underneath the 'New' main ribbon tab button.
Radiofreak
Found it and have done the job. Thanks Bernd.
