Can double click on a cart open PFL?
franksiegers
Is it possible to have double on a cart open the PFL player instead of playing the cart?
That way double click on a cart would be more consistent with a double click on a playlist entry or browser entry.
I use the mouse only for PFL and the Airlite to start tracks and carts.
Greetings,
Frank
Greetings,
Frank
Re: Can double click on a cart open PFL?
No, that is currently not possible. Every double-click also comes with a previous click.
Also does not every user have a D&R mixer and operates it like you.
Thus the cartwall needs some special handling...
A new v4.2.0.3.-Update is available, which now allows an additional double-click mode for the cartwall:
None: The cart starts/stops playing on a single click and doesn't do anything on a double-click. A cart can be selected by clicking on its ID field. Use the right mouse button for dragging the cart track.
Play Cart: The cart starts/stops playing on a double-click and you can select the cart on a single click.
Use the left mouse button for dragging the cart track.
PFL Cart: The PFL player is invoked on a double-click for that cart and you can select the cart on a single click.
Note: Playing the cart is NOT possible via a simple click in this mode, it plays via a right-click here!
franksiegers
Thanks, I've upgraded and went to Settings > Player settings and set Cartwall I OnDoubleClick to PFL Cart. Now when I double click on a cart, the PFL player opens, which is great! Unfortunately, a single click still plays the cart instead of selecting it.
Also, the Cartwall II OnDoubleClick option is called Play PFL while Cartwall I option is called PFL Cart.
Could you perhaps take another look please?
Thank you,
Frank
Thank you,
Frank
Uups, oh yes, that needs indeed to be fixed in the next version!
Fixed in the latest v4.2.0.4
franksiegers
I've tested 4.2.0.4. with PFL Cart / Play PFL:
- Single click: Selects cart as expected.
- Double click: Start PFL as expected.
- Right mouse: Plays cart as expected.
- Single/double/right click on ID field: does nothing.
In this mode, there doesn't seem to be a way to open the context menu for a cart. Could this be assigned to right mouse or ID field?
Cheers,
Frank
Cheers,
Frank
This is already possible - hold the CTRL-Key and make a right-click in case you selected the "Play PFL" mode to show the Context-Menu.
franksiegers
Great, thanks!
Should finally be fixed in v4.2.0.5
