Histroy?
LESH FM
Histroy?
Post by LESH FM »
Hi All,
just wondering if there is a way i can check what tracks have been played for the previous week/month?
Re: Histroy?
Sure, there is an extra Statistics app available for you.
Make sure you have enabled the ‚Keep Global Statistic Log‘ in the general settings. Section Logging/History.
You will find the ProppFrexx Statistics App in your installation menu.
A tutorial video can be found here, starting at minute 21:00.
https://www.youtube.com/watch?v=bcQvCdJ ... e=youtu.be
(or see the tutorial videos in the general folder here in the forum)
Bninane2020
Re: Histroy?
Post by Bninane2020 »
Is it possible to see with a playback history between 0:00 and 23:59:59 for each day?
I see just 3 hours of details.
Thank you all
Re: Histroy?
The History is a list of tracks used for the direct history checking during the scripting.
As explained in my previous post, yes, you can use the statistics feature to list and view all played tracks per day!
