Problem with duration of some broadcast
This forum is unmoderated!
Bninane2020
Post by Bninane2020 »
Hello everybody,
Sorry but my first language is french.
I have a problem with the overlay sheduler with proppfrexx on air.
the duration of some broadcast is 1:02:00 for example.
For the overlay sheduler, i want of all broadcast have a duration of 1 hour.
For to have for the example :
8 pm the cover
9 pm best of pop rock
08:00:00 with statut fix for the moment start at 08:01:00 if the broadcast before have a duration of 1:01:00
09 :00:00 with statut fix for the moment start at 09:01:00.
Have you one solution of my problem for to be always the top of hour with not overlay.
Thank you so much.
Re: Problem with duration of some broadcast
When you look at the StartType of an overlay scheduler or program scheduler entry, you can set the StartType to "Fixed".
This ensures, that it will start exactly on time.
However, what I don't understand in your post is, that you mix broadcast (I assume you mean your program) and overlay.
Your broadcast (i.e. program) should actually be started via the program scheduler?!
Bninane2020
All Broadcast started with overlay scheduler with type fixed.
I don't know why.
I suppose that I must to use program scheduler.
Correct!
Overlays are intended for adverts, traffic, news etc.
Thus, overlays are always guaranteed to be fully played.
Only programs are interrupted by either the next program or an overlay.
Bninane2020
And for differents rotations.
The rotations must to be in the program scheduler?
And the top the hour in the program scheduler too + the broadcast together?
Thank you.
All ProppFrexx related question should be placed in the "Question & Answer" seciton!
Yes, you can plan what ever rotation with the Program Scheduler: See the "Program Scheduler" tutorial here: https://www.proppfrexx.radio42.com/foru ... f=5&t=1018
For TOTH you basically plan the first track in a script as the ToTH-Track, e.g. make a search here in the forum:
https://www.proppfrexx.radio42.com/foru ... mit=Search
Bninane2020
Thank you very much.
