Problem/bug Script Library Editor - Filter settings
AFM-Radio
Post by AFM-Radio »
probably i found a bug or problem in the script library editor.
And then with filter settings. There we use a filter called: 'Last Played in Days' for some script lines.
But since the last update, it doesn't return any results. While this was the case before. See screenshot attachment.
I have tested it several times. Several days filled in, media libraries and so on.
I have temporarily removed the filter from my script otherwise those script lines will not be used.
I don't know if this is only with this type of filter or maybe several. For example, we also use 'Duration is less than' filter and that works well.
Greetings
Jesper
AFM
Re: Problem/bug Script Library Editor - Filter settings
I’ll have to check that!
What type of media library are you using? A folder or playlist based ?
And if it is a playlist based, can you send me your ,pfp file, resp if it is a folder based, the _sxnced_.pfp file?!
AFM-Radio
Post by AFM-Radio »
radio42 wrote: 10 Nov 2020 23:23 I’ll have to check that!
We use folder based media libraries.
I have attached a _synced_.pfp here:
_synced_.rar
(34.67 KiB) Downloaded 243 times
I can confirm, that this is indeed a bug introduced in the latest version!
I am preparing a bug-fix release asap!
AFM-Radio
Post by AFM-Radio »
radio42 wrote: 11 Nov 2020 17:12 I can confirm, that this is indeed a bug introduced in the latest version!
Thank you for the quick response!
A new version 4.2.2.0 is out!
Attention: Make sure to have the latest .Net Framework v4.8 installed!
AFM-Radio
Post by AFM-Radio »
radio42 wrote: 11 Nov 2020 18:12 A new version 4.2.2.0 is out!
That was fast! Thanks! I installed the update and it works fine again!
P.s. .Net Framework v4.8 is included with Windows 10 build 1909 I guess?? Could not find it. But Proppfrexx works well so I guess it is. :-)
Yes, .Net 4.8 is there a long time and the default on Win10. But a few users might still use a previous version on an older OS.
Glad to hear its fine again.
