Small changes in layout after restart
franksiegers
I'm using a pretty large (27" inch) 4k monitor with Windows 7 (don't ask
). Resolution is 3840x2160 and text size 'normal (125%').
I've created and saved a workspace, see:
When I close and restart PFOA, some sizes are changed. For instance, the cartwall is too small to show 2 columns and the mixers height is wrong:
I've tried disabling General Settings > Look and Feel > Save Layout on Exit and updated to 4.2.2.0 which has the same problem. I've created a new, simpler layout, which solves some of the problems (like the cartwall), but the mixer is still too low.
Could you perhaps look into this?
Cheers,
Frank
Cheers,
Frank
Re: Small changes in layout after restart
Unfortunately I cannot reproduce that here.
Note, that the Workspaces are just alternative 'scenes'. By default, when you close PF, the current window layout and size is saved and restored exactly as before.
Here is my layout once I arranged it almost exactly like yours (resolution is 3840x2150): And here is the screenshot after the restart - they are exactly the same: So maybe you simply try to Reset the Layout (e.g. in the general setting, section Look and Feel), restart F and than re-arrange newly?!
