Question
97underground1
Question
Post by 97underground1 »
Bernd. I have a question and what is your best answer
Scenario
I have a scripting that says sweepers
In that file folder it has about 25 mp3s
What setting should the mode be set to
What setting should the options be set to
For the mp3s in the script line to play all of whats in the folder before the mp3s repeat themselves
Re: Question
Mode=Sequential
Options=SuppressHistoryCheck, SuppressAddHistory
D3R3K
Re: Question
Post by D3R3K »
Both options or just one?
D3R3K
Re: Question
Post by D3R3K »
Should there be no script line warnings ?
and one more question. i have 3 music files
one has 10 songs
one has 16
one has 8
what in your opinion would be the best mode and options for them as well? thank you
Radiofreak
Re: Question
Post by Radiofreak »
Can you explain exactly what you mean? Try to indicate what you want to do with the script.
D3R3K
Re: Question
Post by D3R3K »
if i want to have all the songs in each one of those script lines play without a repeat till the list has completed
Re: Question
With 3 music files, I assume you mean 3 media libs?
As they are also pretty small (probably smaller than your global history settings) I would apply the same settings, but maybe use the 'LastTimesPlayed' or 'LastRecentlyPlayed' mode. This will assure, that the least times played tracks first, but give for the same values a random order, which is much better than pure Sequential, as in your first requirement.
Re: Question
D3R3K wrote: 18 Nov 2020 17:48 if i want to have all the songs in each one of those script lines play without a repeat till the list has completed
That requirement is the pure "Sequential" mode!
Example (with 9 tracks):
1,2,3,4,5,6,7,8,9,1,2,3,4,5,6,7,8,9,1,2,3...
Is that really what you want?, as this is typically very predictable and boring and even often being noticed by the listener.
D3R3K
Re: Question
Post by D3R3K »
i have way more music that that . that is my power rotation only 10 songs that need to be rotated so onl one of the songs play an hour for 3 hours then they can start over again
