Playlist
klinkhamer49
Playlist
Post by klinkhamer49 »
Hi how is it possible that I cannot scroll a song in the playlist of proppfrexx, maybe a setting has been changed.
regards
Jeichienus
Re: Playlist
I do not understand. Can you explain in detail what you mean?! Is maybe a dialog open? Are enough tracks in the playlist. What version are you using?
I have never heard about such issue!
Radiostar929
Re: Playlist
Post by Radiostar929 »
Bernd. Wishing you a happy new year. I have set up my own account to dialogue now. Everything we have discussed is now in place a working fine. Thank You!. I do have one more question. I have an over night format for songs. It has two libraries. One has 100 songs in it, the other has 500 songs in it. In your quick recommendation, what should the mode and options be set to for ProppFrexx to rotate all the songs in those libraries with mimimal repeats till all the songs have been played. Thanks for your help.
Re: Playlist
With minimal repeat, this is the LeastRecentlyPlayed mode. No extra history needed. Just a normal/small global history. Note, the the repeat would be independent for each lib. Now it depends on how often you want the two libs to be played.
If both libs should be equally often played, either put them in two distinct script-line - or if both tracks should be played equally often, use 5 times more the bigger lib than the small lib.
