.net Framework error & update 4.2.3.0
jsonio
Post by jsonio »
PF just threw this error in mscorlib:
I see that :
- the update to v4.2.3.0 contains :
- the pending windows KB4586876 update contains:
Will those updates solve the problem or is this unrelated?
Thank you a lot in advance!
jsonio
Re: .net Framework error & update 4.2.3.0
Not sure, but could be. You should definitely use at least the 4.8 .Net Framework or higher.
What have you exactly done when the error came up?
jsonio
Post by jsonio »
- The error came up when I tried to open the scheduler
- Do you mean that the .netFramework version included in the last W10 build could be under 4.8? Isn't .netFramework a part of Windows?
Thank you a lot !
Yes, it is part of Windows.
And if followed all updates, it should be there. But I don’t know that from here, as you skip or dismiss updates.
But if you are sure 4.8 or higher is already installed - all should be fine.
Can you reproduce the error? Is it happening all the time?
jsonio
Post by jsonio »
This problem is not yet solved.
Do you have any news about the fix?
Thank you very much,
jsonio
The most recent version is v4.2.3.1 (in which the initial error posted should already be fixed) and it requires the :net Framework v4.8 or higher (as noted in the News and Announcements), which needs to be installed prior to the update - this can unfortunately not be done in an update by myself, as it is related to a Windows upate/change.
jsonio
Post by jsonio »
The error is still there in 4.2.3.1
I will check one more time if something is wrong with .NET framework
jsonio
Post by jsonio »
I'm trying to know which version of .NET framework is installed and here is the output... sorry, i'm not sure about what is does mean...
C:\WINDOWS\system32>reg query "HKLM\SOFTWARE\Microsoft\Net Framework Setup\NDP" /s
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\CDF
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\CDF\v4.0
HttpNamespaceReservationInstalled REG_DWORD 0x1
NetTcpPortSharingInstalled REG_DWORD 0x1
NonHttpActivationInstalled REG_DWORD 0x1
SMSvcHostPath REG_SZ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\
WMIInstalled REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727
CBS REG_DWORD 0x1
Increment REG_SZ 4927
Install REG_DWORD 0x1
OCM REG_DWORD 0x1
SP REG_DWORD 0x2
Version REG_SZ 2.0.50727.4927
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1028
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1029
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1030
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1031
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1032
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1035
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1036
CBS REG_DWORD 0x1
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
SP REG_DWORD 0x2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1038
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1040
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1041
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1042
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1043
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1044
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1045
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1046
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1049
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1053
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\1055
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\2052
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\2070
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\3076
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v2.0.50727\3082
MSI REG_DWORD 0x1
OCM REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.0
CBS REG_DWORD 0x1
Increment REG_SZ 4926
SP REG_DWORD 0x2
Version REG_SZ 3.0.30729.4926
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.0\Servicing
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.0\Servicing\Windows Workflow Foundation
CBS REG_DWORD 0x1
Hotfix REG_SZ
SP REG_DWORD 0x2
SPIndex REG_DWORD 0x0
SPName REG_SZ SP2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.0\Setup
InstallSuccess REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.0\Setup\1036
CBS REG_DWORD 0x1
Increment REG_SZ 8795
SP REG_DWORD 0x2
Version REG_SZ 3.0.30729.8795
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.0\Setup\Windows Communication Foundation
ReferenceInstallPath REG_SZ C:\Program Files\Reference Assemblies\Microsoft\Framework\v3.0\
RuntimeInstallPath REG_SZ C:\Windows\Microsoft.NET\Framework64\v3.0\Windows Communication Foundation\
Version REG_SZ 3.0.4506.4926
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.0\Setup\Windows Communication Foundation\1036
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.0\Setup\Windows Presentation Foundation
(par défaut) REG_SZ WPF v3.0.6920.4902
InstallRoot REG_SZ C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\
ProductVersion REG_SZ 3.0.6920.4902
WPFCommonAssembliesPathx64 REG_SZ C:\Windows\System32\
WPFNonReferenceAssembliesPathx64 REG_SZ C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\
WPFReferenceAssembliesPathx64 REG_SZ C:\Program Files\Reference Assemblies\Microsoft\Framework\v3.0\
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.0\Setup\Windows Workflow Foundation
(par défaut) REG_SZ Windows Workflow Foundation
FileVersion REG_SZ 3.0.4203.4926
InstallDir REG_SZ C:\Program Files\Reference Assemblies\Microsoft\Framework\v3.0\
MajorBuildNum REG_SZ 4203
ProductVersion REG_SZ 3.0.0.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.5
CBS REG_DWORD 0x1
InstallPath REG_SZ C:\Windows\Microsoft.NET\Framework64\v3.5\
SP REG_DWORD 0x1
Version REG_SZ 3.5.30729.4926
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v3.5\1036
CBS REG_DWORD 0x1
SP REG_DWORD 0x1
Version REG_SZ 3.5.30729.5003
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v4
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v4\Client
CBS REG_DWORD 0x1
InstallPath REG_SZ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\
Release REG_DWORD 0x80ff4
Servicing REG_DWORD 0x0
TargetVersion REG_SZ 4.0.0
Version REG_SZ 4.8.04084
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v4\Client\1033
CBS REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v4\Client\1036
CBS REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v4\Full
CBS REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v4\Full\1033
CBS REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v4\Full\1036
CBS REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v4.0
(par défaut) REG_SZ deprecated
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Net Framework Setup\NDP\v4.0\Client
Version REG_SZ 4.0.0.0
The error has nothing to do with a .Net update.
It seems to come from a UI component library which I am using- unfortunately nothing I can directly solve by myself.
But I reported it already to the vendor to, if I can get it fixed.
I assume it doesn’t happen frequently?
Or are you able to reproduce it?!
