recording
klinkhamer49
recording
Hello bernd Since the new update I can no longer place a recording, it may be due to the update
Greetings, Jeichienus
Re: recording
I don’t think so, it seems unrelated to the update, as here on 3 test systems it is still working fine. I also contacted angewiesen user and they also confirmed no issues.
So please check your system, the recoding and mixer settings. Maybe just a simple path thing?
klinkhamer49
Re:
Thank you Bernd I will continue searching, thank you anyway for the support.
Greetings Jeichienus
