songs
Radiostar929
songs
Hi there I have been running the software for weeks with a 450 file library and one 120 file library the senntings are least frequenty played and forced library check . Do you suggest something differnt to get a better variety of songs played? Thank you
Re: songs
I assume you ment the LeastRecentlyPlayed mode.
The rest more depends on your script and what other options you used.
Depends on your history settings and eventual other restriction or rule sets.
But in general this sounds very good!
