Mixer settings
Radiofreak
Mixer settings
Post by Radiofreak »
I am using an analog mixer and I would like to use the players and cartwall per channel for a live show. My question is, is there a simple way to switch from standard rotation to live and back again so that I can turn the mixer off again? E.g in rotation the players plays from the play channel to the out channel. When going live i set settings to all players and cartwall to seppared channels on the analoge mixer. And after the show back.
Re: Mixer settings
Sure. In the general settings, section Input/Output you can define a normal and an alternative routing.
This can be switched by the ‘Manual Live Assist’ (Automation) toggle button in the ribbon tool bar.
Ie. In live assist mode one routing is used, in automation mode the other.
Guess that is what you are looking for?
Radiofreak
Re: Mixer settings
Found it. Thanks Bernd.
