Block help menu
Block help menu
it is possible to use the help menu at the top right which includes help, mixer setup wizard and backup. and so on able to block for standard operator ?
regards, Tatje
regards, Tatje
Re: Block help menu
I am really sorry, but I did not get your question?!
Do you want to disable that menu?
Re: Block help menu
Yes only for standard operatorradio42 wrote: 21 Apr 2021 18:48 I am really sorry, but I did not get your question?!
Re: Block help menu
When you have enabled UAC (note, that the Enterprise Edition is needed), the following right enable or disable the menu (also in the help):
AllowSettingChanges = Mixer Setup Wizard
AllowSettingChanges = Create Backup
AllowSettingChanges = Restore Backup
As such, yes, that is all supported and working fine.
Re: Block help menu
Oke Bernd, i have the Enterprise Edition.
En its works thank you for your quick answer.
you have a good service.
Regards, Tatje
Regards, Tatje
