Issue after upgrade to 4.2.4.2
CoolRadio
Post by CoolRadio »
Dear Bernd,
Since upgrade to 4.2.4.2. I loose "program schedular" settings every time I restart ProppFrexx. Also UCA is greyed out so no option to disable UAC anymore
Any setting changed?
Regards
Richard
Re: Issue after upgrade to 4.2.4.2
No, non of these settings have changed and I can even not reproduce those!
In v4.2.4.2 Monod this will not happen here.
I assume the root cause of your issue must be something different. From what you explain it more sounds like you have been using UAC, but now do not even have an Enterprise license?
As only in the Enterprise license the UAC option is enabled?!
Can you please send me your license information to check that state here. Thanks.
From your personal mail, it seems, that you licensed the Professional Edition.
UAC is however only supported in the Enterprise Edition.
As such, it seems quite obviously, that this is option in grayed out.
As such, you maybe have used UAC options heavily during the demo phase, never disabled them, but now only licensed the Professional Edition.
If that is true, you should either clean up your configuration first; or even temp. revoke your registration to fall back to the demo version. Then remove those UAC option and after that re-enter your license data while the UAC mode was deactivate.
After that it should all work fine again.
