on air light
Radiostar929
on air light
Post by Radiostar929 »
Bernd How do I get the on air light icon to light up?
Re: on air light
You mean in the header of ProppFrexx resp. the Remote App?! However, that icon is on, once an input mixer channel is ON and the fader is up.
Radiostar929
Re: on air light
nope it does not go on like you suggested its the red mic in the upper right hand corner
Re: on air light
There are two more conditions:
a) the input mixer channel must also be unmuted
b) in the input mixer channel configuration you need check the "Unmute On Talkover" opion
In the configuration dialog, click on the '?' at the top right to get detailed help for each option.
...In addition this option must be enabled to consider this input for the OnAir state!
