Using PF again after 200 days? Nope
SiriusRadio
Post by SiriusRadio »
Hi Bernd.
I've used PF since any time no more. This mornig i had the time and tryd using it again but i couldn't.
First, it never got further than the lay out and stucked.
I did what i always did, adjust the layout file incl. old, rebooted PF again and it turned out fine until i saw that my registration screen was popping up. Were has this infomation? The registration was valid
Re: Using PF again after 200 days? Nope
Nothing is changing on the ProppFrexx side, or deactivated etc. because you haven’t used it, something must have changed on your side I am afraid!?
Else try to re-download the latest version. If your registration is still valid, ProppFrexx must somehow start, else how can you check?!
Please send someone screenshots or error you get.
Else I wouldn’t get any details.
SiriusRadio
radio42 wrote: 05 Jun 2021 15:43 Please send someone screenshots or error you get.
Did not work,
I added all the info i had, now i've heave to request an Key. That brings me back to the website...... a bit puzzled now.
All i need is the key and i can go on
Will
If the Ident-Number is exectly the same as 200 days ago, you still have the registration data and need to enter it!
Else, you need to transfer the license and need new keys.
This is explained in the general forum….
But as your complete name, mail etc. is missing, I guess that this PC was never registered. Or reformatted or…
