Media Libraries how to add more folders and subfolders at the sametime
This forum is unmoderated!
ketofm
Post by ketofm »
Hello
I have 110 Artist's name in folder and in each folder i have 4 or more subfolder for albums in years. like 70's 80's
how can i add all folders and subfolders at the same time with folder names
b/c i have a long folders media libraries in my hard drive
like music/man/artists/name1/album1
music/man/artists/name2/album2
music/man/artists/name3/album3
i have about 110 folders
how can i add all at the same time in media library with folders name?
Re: Media Libraries how to add more folders and subfolders at the sametime
Do you want to keep them as separate media libs or all in one lib.
If the latter just add the root folder.
If the first, you need to add them manually folder by folder.
ketofm
Post by ketofm »
separate media libs
If these are folder based libs, you can simply select the multiple folders in your Windows File Explorer and then drag and drop them from there into the Medila Libraries dialog (open it e.g. from the Scheduler ribbon tab - Libraries - Media Libraries).
