${cpltracknamecurrent} and \${cpltracknamecurrent} changing from current to next
I've noticed this evening that no matter what deck is being used as "CURRENT" ${cpltrackalbumcurrent" and "${cpltracknamecurrent}" results will change to show the "NEXT" metadata if the url stream metadata changes while it's waiting in "NEXT".
I was under the assumption that cplTrackNameCurrent is the current track and cplTrackNameNext is next track to be played as shown in ProppFrexx?
Re: ${cpltracknamecurrent} and \${cpltracknamecurrent} changing from current to next
After some testing, this also affects any command related to getting metadata even getting the details from the deck eg: ${cpltrackalbuma} ${cpltrackalbumb}. They change in the same as mentioned above when a streams metadata is updated while waiting as "NEXT".
Your understanding is correct.
I will take a look, if that is a bug and what it is...seems to be a bug, which will be fixed in the next release!
I was getting confused why it kept giving me unexpected results(even for current type switching from music to Internet stream for the same reason) until I investigated.radio42 wrote: 24 Jun 2021 07:45 Your understanding is correct.
Thanks I’ll look forward to the update.
Just noticed you've dropped v4.2.5.1. Does this update include the fix for this issue?
I've just installed the update and from my initial test it appears to be working as expected.
Thanks for your hard work, it's very much appreciated!
