Columns
Radiofreak
Columns
Post by Radiofreak »
Where are the columns? I can't found the "Listeners Count" anymore.
Re: Columns
If the columns are not in the customization list, they are already displayed - maybe they are resized so small that you don’t see them?
What you can try is to close PF, go to the AppUserData folder of ProppFrexx (%appdata%\radio42\ProppFrexx ONAIR\4.0) and delete the streaming .layout file.
Bob Van Dongen
Re: Columns
Post by Bob Van Dongen »
The first three columns are just too wide. I would like to slide them narrower so that other columns fit better. thank you so much for your response
Re: Columns
Please see your other post for the answer: https://www.proppfrexx.radio42.com/foru ... php?t=3337
No need to post the same question twice ;-)
