windows 11 messed up my audio config
moogwill
Post by moogwill »
Hi, just updated from W10 TO WIN11 a laptop used for RvT this morning, and it messed up a bit the audio, i tried a few things, but non PFOA wont open anymore, it's stucked at creating mixer in the loading window.
how to force PFOA to open?
thanks.
Re: windows 11 messed up my audio config
You need to close PF and delete the file called „Default.mixer“ contained in the ProppFrexx AppUserData folder.
Sorry for that work - it I can unfortunately not prevent this.
moogwill
Post by moogwill »
unfortunately that was the first thing i did, it first opens like on the first run asking me to configuere in an out, then shutdown right after the start, then stuck at each start, even when i delete the file again :-(
moogwill
Post by moogwill »
a few more data about this, i did it again, but this time with mixer an mixer.bak deleted, i was able to start again the audio configuration, then i finally got stucked on this error window
This error message almost means what it says: you do not have permission to the specified file.
This is NOT normal and normally it does not happen, as the user with the name 'quent' always has access to that path and file. So something (not ProppFRexx) must have removed this right or you are using it with a different user?
You need to check your system and its rights and permissions.
Unfortunately nothing I can help with from here.
moogwill
Post by moogwill »
thanks, that exactely what i thought, and i found the issue ;) have a great evenening.
