Sequential jingles not working properly
JWvanGulik
Post by JWvanGulik »
Hi Bernd, another small topic to address. I have in my scripts the Jingles played (range 2 to 6) "Sequential", but in the playlists this is not always done. It happens frequently that the same jingle (!) is played twice in a row (so with music tracks in between). Any idea how this is possible? Thx, JW.
Re: Sequential jingles not working properly
Is the lib or even the script of that Jingles maybe reloaded or reset in between? EG. because you reload them automatically the current pointers are reset.
How many Jingles are in that lib?
As else it should not be possible.
JWvanGulik
Hi Bernd, my libs are reloaded every hour, so that could be an issue and the script is starting every hour. I have 12 jingles in the lib, of which some are only played in the weekend.
