Sweeper mode - volume points are not adjusted on air
Steve FamilyRadio
one of our stations is using sweepers over the intro's of the music, wich are scripted with track insertion mode.
Although when proppfrexx plans a sweeper, we can see that the volumepoints are drawn in for attenuation, but when on air or through pfl the volume is not lowered. Would you have any idea why this happens?
Thanks,
Steve
Thanks,
Steve
Re: Sweeper mode - volume points are not adjusted on air
No, I just double checked it here and could not reproduce.
What insert transition mode did you choose.
May be you can send me a small playlist with one or two items and the sweeper track to try to reproduce it here on my side.
Update: I was able to reproduce it!
Fixed in the new v4.2.7.5 - so please "Check for Updates...".
Steve FamilyRadio
Dear Bernd,
thank you so much, we updated ProppFrexx with the new version, and indeed everything works fine again
Thank you!
Greetz,
Steve
Thank you!
Greetz,
Steve
