the search engine. how do i just browse
fjb59
Post by fjb59 »
although the search engine is very good i don't see a way to just browse the library. is there one?
Re: the search engine. how do i just browse
When you select a media lib, you can just enter * and press enter to select all entries of that lib.
But this is ‚only‘ available, when you also have selected one media lib. As else all search effects all libs.
fjb59
Post by fjb59 »
radio42 wrote: 06 Aug 2022 18:48 When you select a media lib, you can just enter * and press enter to select all entries of that lib.
that doesn't seem to work. am i doing it wrong? in the search engine i select the thrash librry. i go into the find box and press enter. nothing happens. is there a way to just browse everything in the library?
Yes, as said, after you selected one media lib, you need to enter a
into the find box.
fjb59
Post by fjb59 »
radio42 wrote: 06 Aug 2022 20:50 Yes, as said, after you selected one media lib, you need to enter a
into the find box.
asterisk didn't work but full stop did
Here, the asterisk is working - just tested it. What do you mean, by ‚full stop‘ is working?
fjb59
Post by fjb59 »
radio42 wrote: 06 Aug 2022 23:36 Here, the asterisk is working - just tested it. What do you mean, by ‚full stop‘ is working?
i selected the prog rock libary, went to the search bar and pressed the asterisk, then enter. nothing happened. i thought i may have read the symbol wrong so typed full stop, and i got results
