Double tracks
Soulmaster
Double tracks
Post by Soulmaster »
Is there a option in Proppfrexx to search for double tracks and delete them ?
Re: Double tracks
Yes, in a playlist (eg. when you open a media lib) you can use the ‚Remove‘ context menu and ‚Remove Duplicates‘. This will remove entries with the same location.
Or how do you define a double track?
Ie. tracks with a different location are not necessarily the same; different tracks with ‚just‘ the same Artist and Title also doesn’t have to be the same.
Soulmaster
Re: Double tracks
Thnx!!!
