Playing manual, tracks fade out but we do not want it
This forum is unmoderated!
rbsradio
Post by rbsradio »
Hi djs are playing live on manual mode.
Playing a jingle our other track has the result that this fade out. On music less a problem but with shotgun jingles very anoying.
All our waves are trimmed si we do not need cuepoints at all (we use another system for automatisation).
How can we rid off the yellow markers in the 4 players and disable this fade out behaviour please.
It worked fine before re-installation
Re: Playing manual, tracks fade out but we do not want it
a) disable ACPD for the related media types (eg. Jingle)
This should already help. Remove any Cue-Points of those tracks, if already set.
If this is. It sufficient, you can also disable Fading in the main ribbon tab (next to AuroPlay).
