Camelot
Bernarddemol
Camelot
Post by Bernarddemol »
Hello
Is it possible to add a function to schedule with Camelot key in the scripts by filter.
Thank you
Bernard
Re: Camelot
If you mean mixing with according to a camelot wheel based on harmonics?
If yes, the answer is no.
ProppFrexx doesn't use harmonics or calculates a key value for music. But you might use a filter based on the existing meta data fields, like grouping, mood, style, energy etc. to implement something similar. but this has to be tagged and implemented by yourself...
Bernarddemol
Re: Camelot
Just an extra keyword like mood, with a self chosen value. For a filter.
Re: Camelot
As said, you can use any other existing meta data field... and what do you mean by 'a self chosen value'?
