Start MODStream viewer
joshuacarney
Post by joshuacarney »
How to get the best mop for vinyl floor - The ultimate guide
Vinyl flooring is definitely one of the most popular flooring methods for the past few years. According to TheKingLive, some of the main reasons why vinyl flooring is favored can include: Flexibility, durability, natural beauty, low cost and easy to clean. With a proper cleaning tool, you can keep your vinyl floor looking fresh for a long long time. With that being said, we figured that there were still many people pondering the question: “Which is the best mop for vinyl floor?”. This article aims to provide you the answer, we will show you how to find a suitable mop, as well as providing some recommendations. This is “How to choose the Best Mop for Vinyl Plank Floors: Buying Guide and TOP Suggestions
1. Why should you get a vinyl floor mop
One of the most important reasons is that these mops help you to collect dirt and debris more efficiently., as well as making the floor look a lot shinier and brand new, as the floor’s color will fade as time flies.
2. Which is the best type of mop for vinyl flooring
The best mop for Vinyl floor would be a microfiber mop. It has a super soft microfiber mop pad, which not only does it clean the floor more thoroughly, it also minimizes the risk that you will scratch the floor. As vinyl floors are usually vulnerable to sharp or rough material, the mop head will collect and trap dirt and debris within the microfiber strings.
3. Things to consider when buying a vinyl floor mop
Before going to a store or order a mop online, here are something you need to consider:
  • Household traffic: If your house has many people, with high traffic, a strong and durable vinyl floor mop would be a great idea, as that mop will have to work daily in order to keep the floor at its best state.
  • Waterproof: A poor waterproof vinyl floor will require much less liquid, as water can penetrate through the vinyl layer and ruin the adhesive layer underneath. So make sure that you know your floor and ask the seller for an appropriate mop
  • Budget: Vinyl floor mops are varied in terms of price, ranging from very cheap to ridiculously expensive. Take your time to look for a suitable mop at a reasonable price
4. Recommendation
In case you don’t have the time to look up yourself, here are some of ours most recommended vinyl floor mop:
  • Swiffer Sweeper: A low budget, minimalist mop with disposable mop pads, can be used for either wet or dry cleaning
  • Turbo Microfiber Mop: Light weighted, medium price range floor mop, machine washable mop pads, comfortable grip
  • O-Cedar EasyWring Spin Mop: Versatile, long handled floor mop, triangular mop pad for easier corner cleaning, self wringing basket.
Conclusion
We hope that our article has provided you with useful information. For more useful tips and tricks, check out our articles below.
Re: Start MODStream viewer
Just tested it here and it is working fine.
Can you please post your control-command you are using - maybe there is something wrong with that command?
