Advanced filter: filter on directory name
Thijmen
Post by Thijmen »
Say I want to include items in a certain directory, how can I do this? I hoped I would be able to do so with 'Filename' (and not 'FilenameOnly'), but it appears I am not able to.
Can you advise on what to do to filter on directory names?
Thijmen
Re: Advanced filter: filter on directory name
Post by Thijmen »
From this thread: viewtopic.php?t=2894 I can see that "Filename" should also contain the directory. This does not work for me, I try uppercase and lowercase (is it case sensitive?).
Thijmen
Post by Thijmen »
Nevermind, I was being stupid. I did not reload my media library. Hope it may help someone in the future!
Glad you solved it already. Yes, the filename contains the full path, ie. If you want to specifically filter a folder you can also add the path separation char (‚\‘).
