Swap tracks in playlist
Knarrenheinz
Post by Knarrenheinz »
Is it possible to swap the position from two unplayed songs (tracks) in the playlist, instead of dragging them around? For example with a shortcut or a menu button?
I've searched the forum, user manual and menus, but couldn't find the answer.
Thanks for your answer!
Ivan
Re: Swap tracks in playlist
Currently it is not possible to swap two rows - I’ll take a look.
But you can use the Shift+Alt+ArrowUp/Down keys to move a row up/down via the keyboard.
Knarrenheinz
Thank you very much!
This function (Shift+Alt+X or see the Selection context menu plus a control-command) is now added to the new v4.4.1.6 - the first and last row in a selection will be swapped.
Knarrenheinz
Thank you very much Bernd for adding this new feature so fast to ProppFrexx ONAIR!
It works great!
Ivan
tatje
Post by tatje »
Hi, a nice addition, but is there also a command line for this to put this under a button in a novation-launchpad?
Yes. Take a look to the User Manual. The PLS command is called PLS_CURRENT_SWAP_SELECTED, like the _MOVE_xx commands.
