cardwall 1 en 2 not the same
warmeman
Post by warmeman »
For example, if I play cart 1 in cardwall 1 and cart 3 immediately afterwards, they both continue to run. If I do the same in cardwall 2, it fades out the previous card. Why is there a difference between cardwall 1 and 2, and can i adjust this?
Re: cardwall 1 en 2 not the same
The two cartwalls have exactly the same functionality and behavior.
But you can toggle the PlayMode 'One by One' via the context menu!
Make a right-click on the cartwall area (not the cart) and check/uncheck the "PlayMode 'One by One'" option.
