Song Title Updates
JWvanGulik
Song Title Updates
Post by JWvanGulik »
Hi Bernd, it has been a while. After being some time offline I restarted PF, updated to the latest version (4.4.1.6) and now I notice that the song titles are not updated anymore. It could very well be something that I missed, but I cannot find the root cause. Any hints from your side? Thanks in advance. BRJW
Re: Song Title Updates
Nothing changed with song title updates recently.
So if you still have the AutoUpdate enabled, you can even check what is send to the server by looking at the status bar of the network monitor window within ProppFrexx. If that status bar is updated, the server is too.
Also your server log should be updated.
JWvanGulik
Thanks for your quick reply. Do you mean the "Update Song Title" check in the "Streaming" part of Settings and Options? And where can I find the network monitor window? If you mean the "Network Streaming Monitor" window, it says "starting..."
Yes, that one!
„Starting…“ means it tries to connect, but isn’t connected yet - you can click on the icon in front of the starting line to get the current message (if there is one).
Else check your network and the server logs…
