Folder option for overlay scheduling
Cabzy
Post by Cabzy »
When scheduling overlays, would it be possible to add the option to select from folder when selecting the path of the file to be played. (similar to regular scheduling)
It’s more convenient to point ProppFrexx to a folder containing a file instead of selecting the actual file.
If anyone has ProppFrexx server folders shared (as I do) adding a file this way Is much more convenient.
Thanks
Re: Folder option for overlay scheduling
Yes. You can in the Overlay Scheduler specify a script to execute (for overlays it executes as one loop).
And in such script you can define a script-line with the LoadFolder option.
That way you can achieve exactly what you are looking for.
