Switching program and news
owienk
Post by owienk »
If I switch in the "program scheduler" from a non-stop program to a live feed during the news (overlay scheduler), the live feed is immediately unmuted and you hear the news and the live feed at the same time.
In the "input device configuration" the "Mute on overlay" checkbox is checked.
For news during the "live feed" program, it is neatly muted.
Where does this go wrong?
Re: Switching program and news
Yep, you are right.
I assumed, that the input used for manual operations - but you are right, the volume should not be faded-up, if the overlay or the mod stream is also playing in parallel
This will be fixed in the next version!
A new v4.4.4.5-beta version is available - so "Check for Beta-Versions..." to install; this should hopefully fix your issue.
owienk
Post by owienk »
I just tested it.
It works fine now.
Thanks Bernd.
