Bug, GPIO disconnect
wesleyw
Post by wesleyw »
Since the last Windows updates I have been having problems with the GPIO.
It switches off my Velleman and D&R Airence every time ProppFrexx is started.
Even if they are on.
This also happens during the live broadcast, which means that the GPIO always has to be restarted manually.
It's been a while since the last update of ProppFrexx.
When will there be a new update with bug fixing?
Kind regards, Wesley
Re: Bug, GPIO disconnect
I don’t see or experience or can reproduce such issue.
So how could I provide a fix?
I assume, that when the issue was introduced by a windows update, that something got broken in your environment. It is also strange, that both Velleman and D&R disconnect at the same time.
So please don’t reboot of your system and check the connection to ProppFrexx as well as your settings.
wesleyw
Post by wesleyw »
Here the Error log of the last update.
25-2-2024 14:03:43 [v4.4.4.0]:********** Error/Exception Information **********
Error Message: Value Dispose() cannot be called while doing CreateHandle().
Error Source: System.Windows.Forms.Void Dispose(Boolean)
at System.Windows.Forms.Control.Dispose(Boolean disposing)
at System.Windows.Forms.Form.Dispose(Boolean disposing)
at System.ComponentModel.Component.Dispose()
at DevExpress.XtraSplashScreen.ThreadManagerBase.ThreadEntryPointCore(ThreadParameters params)
at DevExpress.XtraSplashScreen.ThreadManagerBase.ThreadEntryPoint(Object params)
at System.Threading.ThreadHelper.ThreadStart(Object obj)
at ProppFrexx.ProppFrexx_ONAIR.h0py(Exception )
at ProppFrexx.ProppFrexx_ONAIR.F0p2(Exception )
********** End **********
24-3-2024 18:53:45 [v4.4.4.3]:********** Error/Exception Information **********
Error Message: Error creating window handle.
Error Type: System.ComponentModel.Win32Exception
Error Source: System.Windows.Forms.Void CreateHandle(System.Windows.Forms.CreateParams)
at System.Windows.Forms.NativeWindow.CreateHandle(CreateParams cp)
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.Control.get_Handle()
at DevExpress.XtraEditors.PopupContainerControl.ForceCreateHandle(Control control)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnHandleCreated(EventArgs e)
at DevExpress.XtraEditors.XtraUserControl.OnHandleCreated(EventArgs e)
at System.Windows.Forms.Control.WmCreate(Message& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at DevExpress.XtraEditors.XtraUserControl.BaseWndProc(Message& m)
at DevExpress.XtraEditors.XtraUserControl.WndProc(Message& m)
at ProppFrexx.ProppFrexx_ONAIR.vmnT(Exception )
at ProppFrexx.ProppFrexx_ONAIR.bmn2(Exception )
at System.Windows.Forms.UnsafeNativeMethods.IntCreateWindowEx(Int32 dwExStyle, String lpszClassName, String lpszWindowName, Int32 style, Int32 x, Int32 y, Int32 width, Int32 height, HandleRef hWndParent, HandleRef hMenu, HandleRef hInst, Object pvParam)
at System.Windows.Forms.UnsafeNativeMethods.CreateWindowEx(Int32 dwExStyle, String lpszClassName, String lpszWindowName, Int32 style, Int32 x, Int32 y, Int32 width, Int32 height, HandleRef hWndParent, HandleRef hMenu, HandleRef hInst, Object pvParam)
at ProppFrexx.DJPlayer.DJPlayerInit(OutputMixer output, String name, Playlist pls)
at ProppFrexx.Playlist.InitPlaylist(Boolean startedByScheduler, Boolean useAlternativeOutput)
at ProppFrexx.ProppFrexx_ONAIR.CreateNewPlaylist(String fileName, Boolean autoStart, String innerPlaylistName, Int32 numPlayers, PlaylistTemplate plsTemplate, Nullable`1 scheduledDateTime, Boolean forceNoLock)
at ProppFrexx.ProppFrexx_ONAIR.TmXo(Object , ItemClickEventArgs )
at DevExpress.XtraBars.BarItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarButtonItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarItemLink.OnLinkClick()
at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link)
at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnUnPressItem(DXMouseEventArgs e, RibbonHitInfo hitInfo)
at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnMouseUp(DXMouseEventArgs e)
at DevExpress.XtraBars.Ribbon.Handler.RibbonHandler.OnMouseUp(DXMouseEventArgs e)
at DevExpress.XtraBars.Ribbon.RibbonControl.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraEditors.XtraControl.WndProc(Message& m)
at DevExpress.Utils.Controls.ControlBase.BaseWndProc(Message& m)
at DevExpress.XtraBars.Ribbon.RibbonControl.WndProc(Message& m)
at DevExpress.Utils.Drawing.Helpers.NativeMethods.UnsafeNativeMethods.DefSubclassProc(IntPtr hWnd, IntPtr Msg, IntPtr wParam, IntPtr lParam)
at DevExpress.Utils.Drawing.Helpers.Win32SubclasserFactory.Win32Subclasser.SubClassProcInner(IntPtr hWnd, IntPtr Msg, IntPtr wParam, IntPtr lParam, IntPtr uIdSubclass, IntPtr dwRefData)
at JQ.mx.Main(String[] args)
Error Message: Exception has been thrown by the target of an invocation.
Error Type: System.Reflection.TargetInvocationException
Error Source: mscorlib.Void SerializationInvoke(System.IRuntimeMethodInfo, System.Object, System.Runtime.Serialization.SerializationInfo, System.Runtime.Serialization.StreamingContext ByRef)
Inner Exception: Het actieve proces heeft alle toegestane systeemingangen gebruikt voor Windows-beheerobjecten
at System.RuntimeMethodHandle.SerializationInvoke(IRuntimeMethodInfo method, Object target, SerializationInfo info, StreamingContext& context)
at System.Runtime.Serialization.ObjectManager.CompleteISerializableObject(Object obj, SerializationInfo info, StreamingContext context)
at System.Runtime.Serialization.ObjectManager.FixupSpecialObject(ObjectHolder holder)
at System.Runtime.Serialization.ObjectManager.DoFixups()
at System.Runtime.Serialization.Formatters.Binary.ObjectReader.Deserialize(HeaderHandler handler, __BinaryParser serParser, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
at System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, HeaderHandler handler, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
at System.Resources.ResourceReader.DeserializeObject(Int32 typeIndex)
at System.Resources.ResourceReader.LoadObjectV2(Int32 pos, ResourceTypeCode& typeCode)
at System.Resources.RuntimeResourceSet.GetObject(String key, Boolean ignoreCase, Boolean isString)
at System.Resources.ResourceManager.GetObject(String name, CultureInfo culture, Boolean wrapUnmanagedMemStream)
at ProppFrexx.ErrorDialog.v6QI()
at ProppFrexx.ErrorDialog..ctor(Exception e, Boolean getFullInfo)
Error Message: Het actieve proces heeft alle toegestane systeemingangen gebruikt voor Windows-beheerobjecten
Error Source: System.Drawing.Void Initialize(Int32, Int32)
at System.Drawing.Icon.Initialize(Int32 width, Int32 height)
5-6-2024 14:46:15 [v4.4.4.5]:********** Error/Exception Information **********
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at ProppFrexx.ProppFrexx_ONAIR.Wlrh(Exception )
at ProppFrexx.ProppFrexx_ONAIR.Olr1(Exception )
at System.Windows.Forms.UnsafeNativeMethods.SetParent(HandleRef hWnd, HandleRef hWndParent)
at System.Windows.Forms.Control.SetParentHandle(IntPtr value)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at DevExpress.XtraEditors.DForm.WndProc(Message& m)
at System.Windows.Forms.Form.CreateHandle()
at DevExpress.XtraEditors.XtraForm.CreateHandle()
at DevExpress.XtraBars.Ribbon.RibbonForm.CreateHandle()
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at DevExpress.XtraBars.Ribbon.RibbonForm.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.Show()
at ProppFrexx.ProppFrexx_ONAIR.NlY9(Object , ItemClickEventArgs )
at I3.Nd.Main(String[] args)
at ProppFrexx.ErrorDialog.j46K()
Hopefully you can see where the problem is.
I have to shut down my system because it can't stay on 24/7.
I mean switching on manually in main (connected) and setting Velleman and d&R Airence control to ON in the status.
During the live broadcast the connection simply drops, everything is set to ON in the GPIO Client, but the connection between the Velleman and D&R to ProppFrexx is still lost.
I'll be back in the studio on Sunday and I can take a look for you if you need any more information.
Greetings Wesley
The error log you showed is from ProppFrexx ONAIR (and not the GPIO client, where the Velleman and D&R client are implemented) - so that error is not any reason for your issue.
However, the above error happens, when you manually opened a new playlist window by clicking on the ‚New‘ ribbon tab button.
The new playlist window could then not be opened due to a Windows error, as you are running out of resources:
The error message translates to:
The running process has used all allowed system handles for Windows administrative objects
This typically indicates a memory issue. This could also be a symptom of a windows update running in parallel.
Also get a reboot might solve the issue.
Please take a look in the AppUserData folder of the GPIO client application, if you can find an error.log file there as well?
wesleyw
Post by wesleyw »
Thank you for explaining where the problem could be.
Below are the last 2 logs from the ERROR log GPIO
(there are no recent error messages)
17-10-2021 14:44:13 [v4.2.6.5]:********** Error/Exception Information **********
Error Message: Kan bestand of assembly Zyan.Communication, Version=2.13.0.0, Culture=neutral, PublicKeyToken=022216e8e71b6602 of een van de afhankelijkheden hiervan niet laden. De manifestdefinitie van de gevonden assembly komt niet overeen met de assembly-verwijzing. (Uitzondering van HRESULT: 0x80131040)
Error Type: System.IO.FileLoadException
Error Source: ProppFrexx GPIOClient.Void toggleSwitchStatusConnection_Toggled(System.Object, System.EventArgs)
bij ProppFrexx.MainForm.toggleSwitchStatusConnection_Toggled(Object sender, EventArgs e)
bij DevExpress.XtraEditors.Repository.RepositoryItemToggleSwitch.RaiseToggled(EventArgs e)
bij DevExpress.XtraEditors.Repository.RepositoryItemToggleSwitch.RaiseEditValueChangedCore(EventArgs e)
bij DevExpress.XtraEditors.Repository.RepositoryItem.RaiseEditValueChanged(EventArgs e)
bij DevExpress.XtraEditors.BaseEdit.RaiseEditValueChanged()
bij DevExpress.XtraEditors.BaseEdit.OnEditValueChanged()
bij DevExpress.XtraEditors.BaseEdit.OnEditValueChanging(ChangingEventArgs e)
bij DevExpress.XtraEditors.BaseEdit.set_EditValue(Object value)
bij DevExpress.XtraEditors.ToggleSwitch.set_EditValue(Object value)
bij DevExpress.XtraEditors.ToggleSwitch.set_IsOn(Boolean value)
bij ProppFrexx.MainForm.Init()
bij ProppFrexx.MainForm.MainForm_Shown(Object sender, EventArgs e)
bij System.Windows.Forms.Form.OnShown(EventArgs e)
bij DevExpress.XtraEditors.XtraForm.OnShown(EventArgs e)
bij System.Windows.Forms.Form.CallShownEvent()
bij System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
bij System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
bij System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
bij System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
bij System.Windows.Forms.Control.InvokeMarshaledCallbacks()
bij System.Environment.GetStackTrace(Exception e, Boolean needFileInfo)
bij System.Environment.get_StackTrace()
bij ProppFrexx.MainForm.GetExceptionInfo(Exception e, Boolean full)
bij ProppFrexx.MainForm.WriteErrorLog(Exception e)
bij ProppFrexx.MainForm.UnhandledExceptionHandler(Exception e)
bij ProppFrexx.MainForm.CustomExceptionHandler(Object sender, ThreadExceptionEventArgs args)
bij System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)
bij System.Windows.Forms.Control.WndProc(Message& m)
bij System.Windows.Forms.ScrollableControl.WndProc(Message& m)
bij System.Windows.Forms.Form.WndProc(Message& m)
bij DevExpress.XtraEditors.XtraForm.WndProc(Message& msg)
bij System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bij System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bij System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
bij System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
bij System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
bij System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
bij System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
bij System.Windows.Forms.Application.Run(Form mainForm)
bij ProppFrexx.Program.Main()
23-8-2023 18:18:20 [v4.4.1.2]:********** Error/Exception Information **********
Error Message: Kan DLL BioDaq.dll niet laden: Kan opgegeven module niet vinden. (Uitzondering van HRESULT: 0x8007007E)
Error Type: System.DllNotFoundException
Error Source: Automation.BDaq4.Automation.BDaq.ErrorCode SnapStop(IntPtr)
bij Automation.BDaq.TInstantDiCtrl.SnapStop(IntPtr obj)
bij Automation.BDaq.InstantDiCtrl.DeinitializeControl()
bij Automation.BDaq.DaqCtrlBase.Dispose(Boolean disposing)
bij Automation.BDaq.DaqCtrlBase.Finalize()
bij ProppFrexx.MainForm.CustomExceptionHandler(Object sender, UnhandledExceptionEventArgs args)
Hopefully you get something out of this?
p.s. What I now notice is that the GPIO Client, the Velleman and D&R Airence protocol do start when ProppFrexx is started.
yours sincerely,
Wesley
If there are no recent error entries, then, there had been no error within the application.
If there was still a disconnect, it looks like a system issue and not an application issue. In such case, I can hardly find or fix any issue - I am lost here as well, I am sorry.
